low res bitmaps in render
Here is an example of what I’ve just experienced. One screen is from max’s viewport, one from Corona’s VFB, texture is a 1024x1024 JPEG, it’s not very high res, but something’s wrong as it looks much better in viewport than in final render.
update: changed texture’s “blur” parameter in mat ed from 1,0 to 0,01 and it looks fine now. WTF?
Yeah, I’m blaming this one on 3dsmax API documentation, or lack of thereof. They give no clue about how to implement some stuff so default bitmaps would display reasonably :confused:
Here you go:
bloooor.7z (494 KB)
I noticed this bug as well, and it happens in all scenes i have. I need to manually change the bitmap blur parameter from default 1,0 to 0,01 to make textures look sharp.
Maybe it’s because I’m working in centimeters?
Resetted xform, changed UVW parameters, added UVW Xform (not even sure what it does) and nothing happens, same blurry bitmap.
Fixed
