Low speed of rendering on PC with 2 processors
Same scene. Textures in dropbox in the same place.
Rays/s total 1,151,362 - i7-2700K
Rays/s total 574,892 - 2x Xeon E5-2650
Or I miss something?
Thank You
does it happen in every scene, or just this one? What are the results from the Corona benchmark - Corona Alpha4 Benchmark scene - Corona for 3ds Max :: General - Chaos Forum?
How to run (import to 3d max?) this scene with A6?
Attach a4 bench all ok.
Try on two scenes… same, in other scenes ok.
false alarm?
Can you still replicate the problem on the single scene - wasnt it caused by for example some random antivirus check running in background?
Tomorrow I will try, thank you for fast reaction and corona.
Hi.
Still same situation with this scene. Turn on, turn off antivirus - speed of rendering unchanged.
Intresting…
That’s it!!!
Textures!!
Use material override, exclude windows glass.
Intresting in that: I use 3 PC - 2 with i7 and 1 with 2 xenons, and both i7 PC’s without override have same speed of render.
Yes it was enabled, but nothing changes when I disable it.
Bingo!
Sorry for wasting your time. Write that to my renderBible.
Thank you.
<3 autodesk
