lower floor of house
Just some new renders on a house ive been working on between projects.
http://www.elfpro3d.com/CORI/
i havent done much light ballancing or color mapping on it yet. i have a big problem with max light like the wall lights which are omnis. its bright right at the start because light is bouncing around in the wall fixture then it isnt bright then its bright again at the roof. problem with max lights is if you put a light next to a surface really close max will ignore light that hits an object at an extreem angle. so close lights never light a surface evenly
looks good.. but there are some lighing errors.. :wink:
such as the ones i mentioned above? or you see something else?
and youve tried small vray lights instead of the omnis?
hi! nice pics! i think there are camera problems at 3rd pic. :?
i really dont like the lighting at all, i’m not talking about the errors but it just doesnt turn me on to the screen very well. i think maybe some daylight pics would be better than being lit by just lights at night.
size of lc2 seems strange (to big)
hmm. id been out of it and never saw the replies to this post hehe. umm. no havent tried vrayl ights instead of omnies yet. ill give them a go. Actually i WISH!!! i could use daylight scenes but the client kept tellling me he wants night shots. none of the camera angles are going to be final shots since this is going to be a fly through anim rather than stills. whats a lc2?
lc2 is the corbusier armchair
dim: 76/67/68 (b/h/t)
inches? i just used it as the same size it was in the file. (i think)
oops sorry cm
did u try ies files?
and maybe better to make your lights with some yellow-orange tint :slight_smile:
hey elf, I’d have to side with giraffe where adding a slight hint of orange or yellow to the lights will “warm” up the room a little.
-dave
ill give it a go. actually due to the flooring in this house i had to turn down the saturation of the GI since everything was way too yellow before. i wouldnt mind convincing the client to go with a daytime shot. his main problem is that when i tried for daytime my exteriors were way too bright. see the post in the render theory section
here is a new render. some furniture change and some tweeks here and there ( i know about the curtain hehe one of those messups) the base of that glass coffee table was supposed to be reed like in the reed post but i stupidly forgot to turn on my displacement in the global rollout
hey man! what with your camera?
Hey Elf thats looking much better.
-dave
shishok i have no idea what your talking about with the camera. if you are trying to suggest to use a camera correction modifyer then you would just have to be dissapointed. these are not final camera shots so im not bother with that stuff just yet
it is not nessesary to always use cam.cor.mod. just raise target to the one level with camera. that is all :slight_smile:
true. well. when i get to finals then ill worry about that. time to move onto the upper floor
