Does curly bracket work in vray lpes? like this for example
CD{0,10}L
my goal is to achieve direct and indirect sss. So my gues is that i need to control the diffuse bounce
direct sss?
C<TD>.L
indirect sss?
C<TD>.{2,}L
probably thinking about this all wrong
Regards Alexis
Hello @LeoYfver , curly brackets are not supported. But you could use a boolean operation as expression, so “(C<TD>.+L)-(C<TD>.L)” should give you SSS without direct SSS
@chakarov thanks so much for this! was scratching my head for along time
could we add curly brackets as a feature request not very important but nice to match lpes as close as possible.
Regards Alexis
