As title :- ). But unnecessary and not wanted. See illustration
VFB+ provides same look with same LUT, but doesn’t clamp the image, retains full dynamic range for post-production ( including white-balance which required dynamic range to work properly).
LUT is mapping from 0-1 to 0-1. So what happens over 1 is undefined - it is a tool of different trade (film). We can make values > 1 unaffected by LUT instead of clamping them, similar to contrast… if that is the desired solution
Yup LUT remaps within 0-1, but it doesn’t mean it must clip everything out of that range :- ). As you see it works perfectly and I used that workflow for whole year on many projects with VFB+.
I have to see what DavinciResolve or something similar does but those LogC files also have dynamic range that I believe are preserved when the whole file is shifted.
And I know some game engines are actually using dense LUTs to do tonemapping. Not even sure how that works but somehow it’s possible.
I honestly don’t know straight out of head what happens, but it did work perfectly in all cases I had.
I’ll try some theoretical scenarios, like one you mention, or applying LUT to fully over-blown render and taking it back to average exposure.
Edit: Photoshop clamps it. Vray doesn’t bake LUT (neither plans on). Imho could depend on LUT, as you proposed, ignore above 1. If the LUT pushes value up, retain dynamic range by ignoring it. If it lowers it than I guess it would clamp the whole range.
I guess it’s too much to ask for extrapolating the expected values for values beyond 1, is this possible at all? I wonder how Rotem did handle overbrights for his VFB+.
Juraj, could you test with VFB+ what happens for values like rgb 2/2/2 with a LUT that visibly introduces a red or blue tint for example? Do values beyond 1 change accordingly or are they left untouched?
I also toyed with some idea of shifting the values outside the range, basically how levels/curves would do. Because LUT can be holder of such information, but yeah, it can do also anything else.
Will try some when I get time, I mostly used LUTs that boost midtones and introduce a lot of contrast.
now when you say extrapolate, do you mean just going with 45deg slope in overbrights, just shifted by the last value in LUT, or going with the same slope as the last segment of LUT?
This. Though kind of hard to think of it that way since it’s not a 1D LUT. I would imagine using the same slope as the last segment of the LUT would cause unintuitive effects if the slope is negative or very steeply positive.
Negative values are clamped to 0.0, there’s no extrapolation for those.
