LUT file in the visual effects
Status: declined
The simple ability to load a LUT file in the visual settings like any other rendering software.
Submitted on AHA Ideas (ENSCAPE-I-1438).
I like what D5 has - AI powered atmosphere match LUTs
Submitted on AHA Ideas by Ondrej Vecan.
LUTs are incredibly simple to use: just load a file, adjust a slider, and you’re done. Twinmotion and D5 Render, both user-friendly software for architects, include this feature. Why dismiss LUTs as irrelevant to the design process? Every architect aims for the best possible images, and LUTs instantly enhance image quality. If you believe LUTs are only for setting consistent moods, think again. LUTs are crucial for accurate tonemapping—something brightness and contrast alone can’t achieve.
I’ve been teaching 3D visualization to architects for over 10 years, so trust me on this. Attached is an example image showing a render done with Enscape and what it would look like with a photographic LUT applied—not for mood, but a photographic effect. This LUT was added in Photoshop, but it would achieve the same result if applied in real-time in Enscape.
Submitted on AHA Ideas by 3D Graphic Academy.
AHA Ideas status: Declined.
Set during AHA Ideas to Discourse migration.
