LUT files in Cameras
Would it be possible to insert LUT`s in the CA Object (like Octane) - this would help a lot.
Hello @acidnoid ,
You can load LUT files in the Layers panel in the VFB2 and save the image with the applied color transformations. You can find more about that here.
Can you share information about your workflow and why you need to add LUT files inside the camera object? Thank you.
Hi Aleksander,
VFB I know - useful - sometimes I have different perspectives and would like to use different LUT’s - if I could save them per Scene in the Cam settings would be quite handy - as I would have otherwise to load for each cam a new VFB setting - switching Cams would be easier.
Thank you.
as far as I see the VFB is in general limited to post editing single renderings
In Corona most VFB settings are overrideable with per camera settings for batch rendering
Thank you both for your feedback. I will forward it to our developers and we will discuss if and how this could be implemented in the future. Thanks.
