LWF Confusing
wow thanks panthon FINALLY I got this this :"Gamma: 2.2
Check Affect Material editor
Check Affect color selectors
Input Gamma: 2.2
Output Gamma: 1.0
what I wass missing :slight_smile: THANK YOU!!!
Yeah , i think it’s all getting mixed up. Most of the people just need brighter scenes, so there’s no need to work in float all the time with exr, applicating luts and profiles everywhere…just too complex, if all that u want is to deliver quickly and efficiently with more light and better distribution. The “all linear” process makes more sense in larger facilities imho.
I’d say lwf is really helpful if one decided to stick to 24 bit images.
As everyone knows, a dark jpg will never look bright, no matter what.
That’s why it’s necessary to “pre-expose” the maps and the renders.
Panthon’s right in saying it’s fairly useless (a cat trying to byte its tail) when working with full floating point images.
All that can be done easily afterwards, as floating point images DO get bright at the touch of a color correction contorl.
Bloody hell, though, i’m starting to dream waves of confused people swamping the forum because of LWF.
I’m starting to bear it less and less, honestly.
There’s more than one long thread on it.
Doing a synthesis of that and making it sticky and CLOSED sounds a bad idea?
Lele
I second that. I suggested the same thing a while ago. Forum would benefit greatly from that :slight_smile:
Oh, with videotutorial! :smile:
third that… 8)
here you go :slight_smile: http://www.chaosgroup.com/forum/phpBB2/viewtopic.php?t=15494&start=0&postdays=0&postorder=asc&highlight=
Can someone confirm my little LWF tests that option 1 and 2 provide Identical results when opening in Photoshop, and option 3 is very very similar.
Option 1
Display Gamma 2.2
Input Gamma 2.2
Output Gamma 1.0
Colour Mapping-Linear Multiply 1/1
Render to Max FB
save with gamma overide 2.2
Option 2
Display Gamma 2.2
Input Gamma 2.2
Output Gamma 2.2
Render to Max FB
save with system default Gamma
Option 3
Display Gamma 2.2
Input Gamma 2.2
Output Gamma 1.0
Colour Mapping-Gamma Correction 1/0.4545
Render to Vray FB
