A recent job I did for an architect. The main challenge of the job was that the house is very narrow, so it was hard to get nice camera angles.
What do you guys think about these renderings?
If the house is narrow you could use clipping cam setting, so you can put camera even outside with the camera clipping plane inside the house; maybe you could also try to add some dof because it seems a bit flat image
Thanks for the tip, but i used clipping and it was still difficult. The house is 15 feet wide and 56 feet long, and the client wanted as much of the room as possible in each image.
