Maintain Additional output connection to material
Hi
I have noticed that when creating additional outputs in Colorcorrect and the other maps, if the connection is directly aplied to the material, the connection dissapears (this doesnt happen if the map is connected to another map), this is very problematic when the map is connected to multiple channels, I wont remember which ones are connected, specially in multisub materials or complicated ones. Could we have a way to preserve the original connection?
Submitted on AHA Ideas (CMAX-I-244).
I think this should be submitted first as a bug report, via ticket on https://support.chaos.com/hc/en-us/requests/new, as it doesn’t sound so much like a new feature, but avoiding something that shouldn’t happen anyway :slight_smile:
Can you send in a ticket, and reply here in the comments with the ticket number? Thanks!
Submitted on AHA Ideas.
Hi Tom, thanks for answering, heres the ticket number Request #438543
One more thing, this is not really important just wanted to know what can I do to avoid that all responses from ideas portal doesnt go to unwanted, every time I notify these mails are wanted but it keeps sending to not wanted.
Thanks for submitting the ticket! You mean emails from the AHA portal are going into spam rather than your inbox? If so, that would be part of your email settings. It’s entirely possible (I haven’t checked) that emails from AHA are a different email address for each Idea, for instance, or changes each time - so you’d need to look for a way to mark a set of email addresses as not spam rather than one specific email address. Can you check to see if the mails are coming from different addresses each time?
If they are coming from the same email address, it might be the content or formatting that is making your email provider mark them as spam / unwanted - in that case you could try adding the email address to Contacts, which should go further than just marking an email address as not spam.
Hope something there helps! I’ll leave the Idea here as New for now, so that we can continue this conversation if need be :slight_smile: But the bug report will actually cover what is mentioned here, and eventually the Idea will be moved to Declined. Thanks! Tom
AHA Ideas status: New.
Set during AHA Ideas to Discourse migration.
