Hi vray’s guys.
After using ACEScg workflow quite intensively recently, I’ve noticed the limited compatibility of the frame buffer tools. Is it possible to add an option to use LUT’s after the OCIO view transform? Of course, the editing is done on smaller data but more predictable and controllable.
Hope my post will help
AC
@piotrus3333 Amazing, it just works flawless!!! I can also create custom luts in davinci that match 1:1 thanks!
sure thing. my pleasure.
version for Corona in one of the other videos.
@piotrus3333 am I too cheeky if I ask how do you made the lut from ACEScg to ACEScc for vray?
Lookup table layer in VFB applies Cineon Log curve to ACEScg and if I remember correctly the lut itself adjust white and black point to mach ACEScc. quite minor shift. I do most of my luts in Fusion/Resolve.
Dear @piotrus3333 , inspired by your work I did some tests and create an ACEScg to ACEScct Log LUT.
I also made a color checker passport color correction to make colors also more precise after ACEScct conversion.
I’d like to share it with you and see what you think about it and maybe inspire new tests and contaminations.
Vray ACEScct + CC.rar (1.77 MB)
Looks ok, probably enough for previewing in VFB.
Consider using SyntheticChart from here: Using ACES Reference Images - ACESCentral to see clearly the whole range, especialy hot highlights.
this is how I do it in Fusion with Color**Curves tool and reference image:
sometimes you need to tweak the curve a bit but generally it’s very decent.
screengrab should be self-explanatory. if not - let me know.
