I have a main workstation licence and one render node licence.
Often I start my other 3ds Max backburner node rendering before I start my main work machine - this means that when I open Max and Vray, I cannot use the working seat licence as it’s in use already.
Is there any way that you can make it so that if Vray is started as a render node in backburner, it will prefer to use the render node licence, and not the main one?
Backburner nodes have never used the UI license, only Render Node licenses. Are you sure this is a licensing issue? Mind if you try it with Arnold? Are you sure the UI license is not used somewhere else? Also, make sure your local license server is active (still needed for network rendering).
I’m not sure what it is - but when I start rendering with backburner first I can’t get the full UI from Vray as it says the licence is being used elsewhere.
I don’t get that issue when I start my workstation first with Vray and then the backburner render afterwards.
I suggest you write a ticket to technical support about this. A remote session seems to be needed to see what’s going on.
