Make corona proxy convent multiple animated selected objects at one time
it is possible to Make corona proxy convent multiple selected animated objects at one time? Something like in Vray Proxy convent menu//
1/Multiple animated objects in one proxy file/!!!
2./Multiple animated objects in separate proxy files/
3/ Condense and create MultiMaterial from selected objects/
4/Support motion blur for animated proxy’s in render/now it’s not work, i understand…
It’s very useful in some situations///
Leafs and Branch for animated trees and etc.
i found CoronaProxy exporter 0.04 but this don’t export animations in single proxy file and don’t create MultiMaterial from selected objects//
Exist some new versions of this plugin???
Because now i need first convent animation to Vray Animated Proxy as single file and after that convent this to corona proxy via script Corona Converter/
This is a bit complicated way for using///
Hi, the exporter still has some limitations.
We are talking about Corona 1.3 for 3ds Max, right?
Looks like it’s not possible yet.
Yes.
Select “export each node…”
Select “animated”
Yes.
Select “collapse and export to single…”
But the animation cannot be saved…
Works fine here.
Since it’s not (yet?) possible to have multiple separate meshes in one proxy file (without collapsing them to 1 object) it’s not supported.
I’d have to build a new single animated mesh from several other objects during export and that’s definitely not a good idea to do in maxscript
having only one animated object in one proxy allows the file to be much smaller and simpler AFAIK, so this is probably not a good idea
Thanks for answer"s guys///
I mean version of Corona Exporter 0.04 with Corona 1.4 Daily Build ///Now not exist something new version, as I understand it…
About exporting animated multiple objects in one proxy file… I don"t know is the good idea or not, but in Vray it works fine and then allows you to not busy with groups of objects in the scene,
moreover, if not very heavy geometry with lot of objects, such as animation of clock mechanism in one proxy, instanced several times in scene and etc.
  • Automated MultiMaterial is very useful thing///
About Motion blur for animated proxy"s objects, it’s not working, if a transformation keys of the object /for example position and rotation transformations/ situated
INSIDE the proxy, something like point Cache in 3dmax///
I hope the new version of Corona 1.4 will be whether the new version of the Corona Proxy exporter
For example: animation like this with leafs i can export to one Proxy Object with ready to use Multimaterial in Vray render with one Click!!!
I get the ONE proxy object for this group with correct Multimaterial and i can change animation’s and frame rate options as i need, and placing any number what i need in my scene///
to keep things simple we will not add support for multiple separate objects in one proxy file
