Make "Pivot placer" faster / easier to use
Status: pending
I use a lot the feature “Pivot placer”, but is is a pain to always select often used settings, as it always opens back in new session as “no change”.
A simple ways to make it more fast & easy to use : put 4 radio-buttons for each axis XYZ : NoChange, Center, Maximum, Minimum
A quite simple thing to code, lots of seconds saved.
Submitted on AHA Ideas (CMAX-I-188).
Hello there !
The Pivot Placer popup would be easyer / faster to use if ypou could replace dropdown list by check / radio buttons
As we often use “center” for X & Y, and “minimum” for Z, it is long to select in lists…
Please see the small montage i’ve done in attached picture.
I think this one is quite simple to code, and will save lot of time for users.
Best regards.
Submitted on AHA Ideas.
AHA Ideas status: Pending.
Set during AHA Ideas to Discourse migration.
