make rectangle light longer than 3 meter
:confused: i think you guys must make rectangle light more longer
I’m curious: what use would you put it to?
Why wouldnt they just extend to match the size of the actual rectangular light… How it currently is is pretty annoying… I end up having to make large light arrays in rhino.
@jessegould Do you mean the light distribution isn’t like expected if the light size is larger than 3m? So far I understand rectangular light based on a kind of point lights, but maybe the RTX technology allow to implement better looking area lights. What do you think @Simon_Weinberger ?
@Micha Light distribution of area lights is different from that of point lights. I don’t have any deep insights into why the limitation exists but I’m pretty sure it is a combination of performance and correctness considerations.
RTX by itself does not allow anything that wasn’t possible before, it is just a performance improvement that allows us to do more/better calculations without affecting user experience.
At one of the RTX videos I heard something about better and noise free area light shadows and so I hoped, this could be implement to Enscape too.
https://www.gdcvault.com/play/1024813/
The workaround for huge area lights is to use emissive objects. This is also very similar to what you have seen in GDC videos @Micha .
If I could make emitters invisible, than I could use emitters. My clients like to get large interior spaces rendered and without visible light source I need to bring light to specific areas. It could be great to switch area lights in a hidden emitters mode, maybe per naming.
+1 to Micha’s post
Thanks, forwarding this +1 to the feature request. :slight_smile:
+1 to Micha’s post
It would also be great to get some feedback as to whether this is even a remote possibility (invisible emitters) From memory when this has been requested in the past it seemed as though this was not going to happen.
Thanks!
