Make the render window addapt to the size of the render in the RenderNodes
i usually render big format renders, and I use local farm and also renderfamrs online.
I often encounter a quite annoying issue where the monitor of the working machine only shows a corner of the render in the VFB, instead of, by default, fitting the render on the screen, that would allowme to check the progress and if the render is good or bad looking.
Is there a way to fix that?
Sometimes I can enter and zoom out a bit… by next render on queue will default again on the same corner… it is annoying needing to log into that rendernodes just to zoom out.
In the online farm this is more annoying as I cannot scroll out in the preview window.
Hi, you could try the setting from the screenshot. it should be set per machine.
