@luisgamino2 I haven’t gotten a chance to reply to your other threads yet. I have been very busy recently with the new Beta
Keep in mind that the experience in V-Ray for SketchUp is very different than V-Ray for 3Ds Max. There is a new version in Beta now for 3Ds Max, it will be available for SketchUp soon
I edited your reply for now until I get a chance to comment on what you wrote, then will edit it back to what you wrote
Many of the points you mentioned are addressed in the new Beta, plus you don’t follow my advice on using progressive mode/Cuda mode for best memory efficiency. I will write about it in details tomorrow
Does it crash out of memory? could you please screenshot me the log
If it is not a memory crash, I will need the scene. Being able to reproduce the crash on our side, I will make sure this gets fixed
>> You should be careful with Displacement using screen space, it is one reason people run into GPU memory limitations. We are aware of this, will take a look at GPU displacement whenever comes a chance, it is high priority on the development roadmap.
>> Stick to Progressive mode, could also stick to Cuda engine which uses less GPU memory than RTX. This is part of the current development effort for V6, to have better memory management.
I would love to help, any crashes that I produce on my side, I will make sure it gets fixed.
On another note, V-Ray 6 makes comparing performance a much easier task. The GPU UI will translates sampling settings from V-Ray to V-Ray GPU under the hood. We also updated the sampling defaults for V-Ray GPU and the underlying formula for calculating samples. Some of the changes are currently in Beta 2, and more will come at the official release
