Need to fix the lag issue when a user goes to render a high quality render. Not sure what happened in 3.0. When I work in Vantage all is good, but once I get into the render dialogue box everything slows down. Selecting settings is slow, selecting where to save the file is slow, then I start the render, renders fast as usual, then after, when try to render another camera, it goes from a 20 render to a 2 hr render. Like the vram is clogged up, or something. I then have to abort, close everything and restart my machine to clear something. Cache, vram? Who knows. I’m in 3ds Max 2025, latest Vray 7 update 2 hotfix 1.
Hi Luma3d,
Can you please try if my suggestion here will fix your lag issues? Render in 3.0.2 Resolution performance problem - Vantage :: Issues - Chaos Forum
Alexander
Ok… I’ll give it a try.
I agree. The new window that appears after pressing Ctrl+R made it harder to manage VRAM usage — the parameters there are confusing and make selection more difficult. I don’t think this change is good at all; something needs to be done about it.
Yes, this is a solution. Thank you.
Ok… Switched and it works.
Ok… I’m back. I’m running into a weird issue. When rendering during a session, Vantage initially start rendering normal. Fast even with high settings for a still. But over time, seems like the cache, vram who knows fills up and for the same image, it goes from my 20 min to 3hrs. I have to constantly shutdown my machine, wait and reboot it to get the same render times as before. What’s up with that?
Hi Luma3d,
Do you mind sharing the scene with us to test on our end? You can use the Chaos Help form with a link to the forum thread: https://support.chaos.com/hc/en-us/requests/new You will have to include all asset files.
best regards,
Alexander
This is something I believe I’ve encountered as well. Yesterday I was rendering a series of panos and the time had gone up from ~2 hours at ~10min a pano to a 4 hour estimate with taking over 30 minutes a pano. Believe that estimate would have continued increasing had I not canceled the renders. This happened twice.
My MAX file is about 700mb… How do I share? Archive it? And upload?
Hi Luma3d,
Yes, you can use File->Archive from Max and send us the created archive. Use the Chaos Help form https://support.chaos.com/hc/en-us/requests/new , there you can upload the archive and once we receive it we can test it if the slowdowns reproduce on our end. You can also attach a debug log from Vantage(%AppData%\Chaos\Vantage\debug_log.txt) when the slowdown happens. Note that you have to send the log when that slowdon happens as it get overridden every time Vantage is started.
Alexander
Are you guys using laptops or workstations for these renders?
We only use laptops… I’ve archived the model and it’s 5.5gb. Is that size still feasible for uploading?
A heavy render on a laptop getting slower over time => I’m 99.9% sure that this is because the laptop is overheating. In this case there’s nothing we can do and the scene won’t help. You could try improving the cooling of your laptop but this will probably only slightly improve the situation. Laptops are just not made for sustained heavy workloads like this (they handle bursty work better, etc).
