If you use Corona Renderer for your rendering, we think this script is for you. This is a very simple but EXTREMLY USEFUL script you will use all the time! It will save you a lot of time!
Documentaion:
All proxy parameters are changing for proxies selected in list only.
“Update list” button – Collect all proxies in the scene and update list. Script should do it automatically when: new scene is opened, object deleted, scene merged.
“AutoSelect” checkbutton – If enabled then proxies selected in scene will be selected in list. Use when you want to control only proxies selected in viewport.
“Affect All” checkbutton – Selects all proxies in list if pressed. Use when you want to control all proxies in the scene.
“Proxies:” counter – Number of all proxies objects in the scene.
“Unique:” conter – Number of unique proxies in the scene (gets only one instance per proxy).
“Ram cache” and so on – Proxy parameters (Captain Obvious).
“Select” button – Select highlighted proxies objects in the scene (hidden objects are ignored).
“Hide” button – Hide highlighted proxies.
“Show” button – Show highlighted proxies.
Installation:
Drag .mcr to viewport. Find “Corona Proxy Lister” in “Corona Render” category and put it to menu or toolbar.
Limitations for v1.0:
– Dialog can’t be resized
– List always sorted by proxy filename.
– You can reorder columns if you want, but script won’t remember it.
Enjoy!
Download this script here:https://cgtricks.com/how-to-manage-corona-proxy-with-corona-proxy-lister/
