Would like to share a recent project, not the most exciting architecturally but the render cam out pretty good, imo.
Vraycam, sun and sky, the sky is driven by an higher sun and has a colorcorrect applied to increase the saturation and darkness a bit.
very realistic image ! what is your vegetation mesh ? evermotion? xfrog? that look’s very good.
Maybe you could add a very small border to the grass, it is very reallistic but it seams to be hardly cut from the other shaders.
Provise - thanks for pointing that out, a last minute “lazy” material change, will do a crop render.
Clifton - yeah pretty lame name for the image, but yes its a place down by the bay next to where I live, actually overlooking the water - I have also done an interior which I will upload soon.
Raistlin - all the vegetation is onyx except for the pandanus trees which I modelled for a previous project, and the grass is just displacement which I have probably overdone a bit - I like to have the grass a bit higher than the hard landscaping.
Very nice image in general.
I like particularly your use of sun/shadow, and camera angle and framing with vegetation. Also I like your sky choice, simple yet interesting.
one of the most realistic cg exterrior shots i’ve seen here. Excellent work. I love everything about it, except the drive way pavement texture. Way too clean and tiled. Not sure if it suppose to be that way.
Great work otherwise.
