A request from our architects is for a manual toggle to turn on lights. I know at the moment it does this automatically based on time of day, but sometimes they want to showcase the lighting during a lighter point. Can an option be added to change lights from Automatic to Manual, followed by an on/off tick box?
actually there isn’t any automatic in place to toggle the lights based on the time of day. However depending on the light’s brightness it might not be clearly visible during daytime. Fortunately you can overwrite the brightness value of all lights in the Enscape settings window (Advanced tab) to be brighter (or less bright).
Certainly technically possible, however we’ll have to check if larger values result in any undesirable graphic effect. This is something we usually want to avoid.
