Manual sync button request
Manual sync button request.
Im working in a large revit file, each time enscape syncs it takes a while for it to load, everything freezes in the meantime. Thats ok, I can turn of sync and work until I need to have a look and turn sync back on.
However, and this is the problem, I keep forgetting to switch on and of. The number of times that you forget to turn enscape of and it goes into the load freeze for the slightest file change, is alomost comical, in fact its become a running joke at the office.
So, I would like to request a manual reload function as an optional setting. It can be a shortcut key, similar to shortcut for render view. When you want update, you type the command.
This would save us time, spare us of large amounts of frustration, and just make the overall userexperience a whole lot better.
I hope this makes sense and you enscape team and you can see the need for this,
Thank you
I requested this feature almost a year ago. A keyboard shortcut within Revit would be amazing for this application.
Revit Keyboard Shortcuts & Enscape
I think I have seen another thread to this effect, and commented on it… but re-upping this request.
This button would make my life/workflow much easier.
Thanks a lot for all your feedback. This topic on our agenda has not been forgotten. I’ve added your upvotes and made sure that our developers know of the further demand for this. :slight_smile:
