Many Vray Lights VS Scattered Poly Mesh Light? Efficiency?
I have a scene where I need to add many sources of small lights. Is there a method that is more efficient than others?
Option A: Use many instanced area lights.
Option B: Scatter my light emitting planes thru the scene and use a mesh light. All connected together (or into color groups)
Option C: ??
Increasing cutoff threshold will help. Anything else?
You may have to do your own R&D to test that.
I often get great feedback here but also there are times when I realise that I have to do my own R&D.
If you already have a complex scene, then you could map out a to do list in order to methodically test shit .
many lights. period. o lot of optimisations available. mesh light is simply VRayLightMtl.
Also how many of them need to be actual light sources VS a plane with vraylightmtl for visual effect
Many lights will probably be better.
Update: Vray area lights worked very well. I have 1300 lights in the scene and probably at least 800 on screen/casting range. No real dramatically unexpected performance hit. Scene looks really nice. Thanks
Not true, a Vray mesh light, has way more control than a simple vraylightmtl does
