Mapping a String
How can I project my bitmap to get the shoe lace aspect on my string?
Thanks a lot.
Zooropa
Re: Mapping a String
The best thing to do would be to use surface projection and mess with the U and/or V repeat to get it how you want it. Do yourself a favor and use the U&V repeats in the Rhino mapping options as opposed to V-Ray options…you can see it in the viewport as opposed to only seeing it in the render
Thanks Dalomar, Can you help me to find the command? where is it?
Thanks Zooropa
There’s no command…when mapping gets applied its automatically set to Surface. If you’re familiar with Rhino’s Texture Mapping interface, then you’ll be fine. Just set the projection to surface.
Oh…i got it. Yes , that’s the way that I always use.
Thank you.
Zooropa
