Mapping Q
Hey to everyone… have a simple question:
How do i know the real size of the concrete tile? It looks a bit oversized, so i would like to have an original look of the ground.
Thank you as always.
Zooropa
Re: Mapping Q
The easiest way to achieve this is to assign a planar map to the ground floor that matches the size of the tile and aspect ratio of the image. For example, if your texture size is 1200 x 900 pixels, and your concrete tile should be 1,20 m x 0,90 m in real life, you set the size in the mapping dialog to 120, 90, provided you are working in cm.
Re: Mapping Q
Thanks you Gijs i will try this one.
:wink:
Zooropa
