There is different behavior with cinema bitmaps or corona bitmaps when mapping randomizer is used. (no/same settings in the randomizer in both examples)
If mapping scale is set to 50%, with cinema bitmap it works as expected, mapping is half the size. When using corona bitmap the mapping size is a quarter of the size not half.
I have a project with a light material for the backgroundphoto placed in the render settings direct visibility environment overrides, set to flat projection. It does not show in the render unless i convert the light material to cinema bitmap and all is normal. No background visible with corona bitmap in the light material. (or scaled to a huge scale that i can only see just a few pixels…)
That was not the case when i worked on that project earlier. Please test and confirm.
I really don’t see why i should use corona bitmap, it only causes problems.
So i only use cinema bitmaps from now on, no problems at all…
Edit: “That was not the case when i worked on that project earlier” that’s because it was set to cinema bitmap in the Light material i just discoverded…
