I have a scene that doesn’t render the maps (say diffuse) when I use Tesl V100, even when I use different file types (like PNG or TIFF or TGA). It does work however with multiple GeForce cards like 2080Ti, MX 940, 870 m, and so on. Is this a limitation of Tesla cards? Are there any workarounds?
Thanks,
Ashkan
Hi Ashkan, there should be no such issues with V100. Can you check the Textures parameters (Render Setup > Perf. > Textures) to see if the issue may be coming from there? For example, if it is set to Resize mode, maybe just the resolution isn’t coming out as expected. If you can share more info, screenshots or screen recordings demonstrating the issue, it would be greatly appreciated!
You can read some further information on GPU Supported Features for 3ds Max here: V-Ray for 3ds Max
