March of the clones
Well, the compression will not change anything in this regard; you have the same thing happening now even without animated proxies.
Confrabulations for your continued work on proxies, Vlado.
Going a bit OT, and speaking of compression, and network traffic/speed, did you do any work on IRMap/LC/Photon Map embedding into the max file (if you remember that script I did that embedded them into nulls…)?
That, coupled with the maxzip compression of the max file should make for even better handing of files across networks.
here is a really good question. maybe i missed it somewhere.
when it reached the end of the animation what happens? can you add in pingpong, loop and hold options? and with pingpong since it will be going backwards would the velocity channel be correct.
There are currently “Loop”, “Play once”, “Ping-pong” and “Frozen” modes.
And with pingpong since it will be going backwards would the velocity channel be correct.Yep.
This is going to be very cool!
the rapture and the joy i feel every time i see this post. doing an army of soldier crabs is now a possibility
Very Nice,
who was that guy who wanted to write the Massive2VRay bridge?
(just kidding)
Dieter
Vlado, sorry to bring this up again, but i’m really curious.
No answer means you’re not planning/haven’t done any work on the subject of saving irmaps and such within the max file?
If so, i’m fairly sure i could turn that test into a workable version to be distributed, only it’d need a bit of care and a wee bit of work, hence the question…
Nope, didn’t have time for this; we had a lot of stuff planned for SP2 but the early release of 3ds Max 2009 will cause us to leave many of the things which are not complete yet for the next update and include only the features that we have completed so far (plus the bug fixes, of course).
now that sounds nice!!
what about things like cloth sim. are they stored too?
and sorry for maybe the dump question, but what is it for a workflow? you can animate with no matter what tool like cat.. and export then to proxi, so he writes sort of a snapshot for each?
when you want to modify, you just export again?
The exporter goes through the specified frames and makes a shapshot of the mesh at each frame. It does not matter exactly how the mesh is animated.
Like with regular proxies, if you modify the object, you’ll need to re-export the proxy.
Thanks for the reply, Vlado.
Will look into it from the scripting side, then.
On the proxies, do they support sub-frame snapshotting as well?
I’m thinking of some jittering motion meant to look good when moblurred, or to a football rotating very rapidly (so that for each frame it always shows the same side to the camera).
Well, i know that guy and you know that guy and i know the bridge is pretty much working :wink: - well at least it’s a massive2max and max2massive bridge…
Sounds like the proxies will be a custom version of what point cache does, so same work flow.
Ah,
last time we met he asked me if it can be done. Nice to hear that he succeeded. But I bet Vray could handle it natively. Anyway, I should have another beer with him. It was a nice chat last time. :slight_smile:
Dieter
If i may, when stored on an NTFS filesystem, it would be easy to have the folder with the saved proxies runtime-compressed (set the folder as compressed when empty to avoid having to wait for all the files inside to be compressed at once, and just have them compressed one at a time…).
That does cut down on disk filesizes a LOT for static proxies, so by the same rule it should do a good job also for animated ones.
Wouldn’t that cause the server to need to uncompress the file every time it is accessed? On a large farm I think that might be deadly for the server CPU plus the added bandwith. I am not sure how compressed folders are handled client/server wise.
Well, compression is already there (file sizes go down 3 to 5 times); I have not made exact performance comparisons yet, except to note that it is not slower than before in any case.
did i miss something. i saw the still of the clones marching. however this topic is about ANIMATED proxies. can we see an animation :slight_smile: :slight_smile: :slight_smile: come on vlado hehe
Damn, I knew I saw that one late… :lol:
