I’m starting a new project, a nice one (Babyfoot games)… And i’d prefer to render it with Corona (fast, nice, i felt in love with it)…
My 2 other historic renderes are Maxwell (too slow for this project), and Vray (not so fast & nice in my opinion)…
Problem is that i’ll HAVE TO get masks, lots of masks, and i must admint that Vray’s option “affect all channels” plus multimatte element is a must have !
It renders the alpha objects taking account of reflexion / refractions…
Can Corona render that ? Will it be able to in a next release ?
Hi, sorry, but this is currently not possible. We have already received feature requests about this and this is high on the todo lists.
Currently the only workaround would be to re-save the scene and “fake” the masks using custom materials (self illumination or lightmtl without emission). I understand it sounds ridiculous, but it looks like this is the only option now…
Do you think it’s something that could be learnt from Vray or is the issue to do with a fundamental difference in how Corona works compared with Vray? i.e not possible?
Corona was not originally designed for doing things like this, so it will take some time to implement it. We do however have it on our TODO.
The current status is “once it will be coming soon, we will announce it”.
We are aware that this is an essential feature for many users.
Unfortunately I still can’t get this in the latest release (6.0).
I did a simple test using corona 6 trial for 3ds max.
So that’s what i need to do just to have masks:
1- Duplicate pillow’s front mesh
2 - Use Push modifier to make it slightly in front of original front mesh.
2 - Set a new multi-sub object ID
3 - Place opacity map on that new material
4 - Set a diferent g-buffer iD for it
Using V-ray, for instance, i just need a vray blend and materials with diferent g-buffer ID’s. No modeling work needed.
EDIT: Sorry guys, I know it’s not about reflection. But I was hoping that it would come together.
I am really sorry, but I do not understand the problem described here.
Could you explain what exactly you are after? What kind of masks do you need to render, and what for?
And maybe you could also show the correct V-Ray result?
Hi Maru.
Yeah, i didn’t express myself well and everything became a mess!
To be clear: I just need masks while i’m using CoronaLayeredMtl.
I need masks to do post-production of products to achieve high precision in color treatment.
For now, i have to use the techniques i said before:
4 - Set a different g-buffer iD for it
In V-ray i just have to use a vray Blend with two materials with different mask IDs.
There is no need to duplicate the front mesh of my models and use opacity maps on the materials.
