Masks in Corona 6
Is there a problem with Buffer IDs and Masks in Corona 6? No matter what I do I just can’t get it to work. They don’t render properly and also the .aec file doesn’t bring in the fully rendered RGB files in After Effects.
could you please elaborate on the issue? Perhaps sending over a scene or maybe a video displaying your issue? From a quick glance masks and object buffer IDs work in my scene, but it is very possible that I’m not going through the same procedure as you are.
As usual, disclosing PC/Mac, version of C4D always help with our investigation.
Thanks,
Jan
Thanks for responding. I’ll put something together for you and send it along.
Here’s a sample of the file I just can’t get to work. The following are my system specs:
2013 Mac Pro
High Sierra 10.13.6
32GB RAM
C4D s22
Corona version 6
After Effects version 17.13
Thanks for your help.
MaskTest.c4d.zip (7.33 MB)
Hi, same problem here :frowning:
Any news regarding this issue :confused:
UPDATE
In fact, I was to quick… I checked my material and it had the “Propagate masks” set to Always…
I just had to set it back to Never and everything was OK…
Hope it helps
