I’ve inherited a scene that I need to render with a vray camera, but I don’t have vray. Is there a way to convert the ‘Camera Stand-in’ object to a Physical Camera? It needs to match pixel perfect to the old vray camera.
Thanks in advance
Thanks in advance
Doesn’t the new Corona 2.0 support vray cameras now?
You could also just install a free trial of vray and convert the camera over to corona.
Oh cool, I wasn’t aware of that. I’ll give it a shot, thanks!
Ok, I have Vray installed and can see through the camera and can render it on my local machine. Now I need to convert this to a 3ds max Physical Camera because the farm doesn’t have vray. How do I do that?
To do it manually it’s not so complicated: align the camera and target and copy the same parameters. =)
You need vray demo only for using corona converter script, corona 2.0 support rendering without vray installed
Thanks for the quick replies. Cecofuli, I had tried that, but it’s off a few pixels which is my problem. I need to match the object in blue to match a pre-existing background plate (this cannot be modified).
Sprayer, the corona converter script doesn’t seem to convert the camera, only materials and lights. I just tried it, let me know if I’m missing something.
I just saying what with corona 2.0 you do not need vray to be installed
You don’t need vray installed for Corona 2.0 to use the VrayPhysicalCamera? I just updated to 2.0 to hopefully fix that but it still brings it in as a ‘camera stand-in’ object. Is there something you have to do to tell it to see it as a Vray cam?
Clarification:
Only VrayMtl, VrayLight and VrayVolumeGrid are supported in Corona 2. Not the VrayCamera. See: https://coronarenderer.freshdesk.com/support/solutions/articles/12000046990
Also, you can render a scene with VRayMtl or VRayLight without V-Ray installed, but you cannot create those objects without it.
Thanks Maru,
Can you confirm or not the ability to render a vray camera in corona with only the vray demo installed?
Or will I need a vray seat to render a vray camera in corona?
I think the demo is enough. But rendering from a V-Ray camera in Corona is not a good idea. You may end up with some exotic bug like flickering in animation, or DR not working. But if you want to experiment, go ahead. ![]()
Ok, I can verify that the Corona camera will render a vrayphysicalcamera with only the demo installed on the node.
I need to use the vray camera in Corona as a legacy fix on this one shot, I don’t plan on using the vray cam in the future ![]()
Thanks for the help guys!
