I need to switch from using a VrayDisplacement modifier to doing it via material because I’m switching to vrayproxies for the mesh, but I am not clear on how to set the amounts in the material (and render dialog rollout) to match the amount set in the mod.
In the mod I have it set at .25cm and offset by -.125cm - how do I set a percentage to match that, and where? Material, or rollout?
Any help much appreciated
b
Actually… I had never tested it before, but it seems that even material level displacement doesn’t work on VrayProxies - is that correct?
EDIT: found out, no joy with proxies and displacement at all. Crap. Have to go at it another way.
b
Just here to tell you I am too late to answer since you already found out
I have no idea why it technically isn’t possible to do displacement on proxies but it is a darn shame! I could have made great use of that countless of times.
