Material accident, something is missing?
Hello guys, I really need you help.
So I inserted a logo in corona version 5 into the corona texture. This went perfectly fine based on the Layered material. Now I’ve reopened the scene with version six and the Corona doesn’t render the way it did before. So some problem happened here. I have checked every folder to see if it was missing by accident, but every bitmap is fine… I have attached the images due to this problem. Thanks for your answer! :slightly_smiling_face:
Thank you!
I might be wrong, but i think this issue was fixed in Corona 6 Hotfix 1. Try to install it and see if it helps.
