I’m new to Envision and testing out vrscene imports from some of our past models and I noticed some peculiar shifts in material assignments on 2nd copies of objects in the models. The models are SketchUp 2025 and 2026 versions and the vrscene exports are from the latest Enscape plugin 4.15.0.276. To see if the type of object has an impact I put together a simple model of cubes with components, groups and loose geometry to see what would happen and I’m puzzled by the results. Only the loose geometry retained the proper assignments. Things shifted for the 2nd copy with Components and Groups. The materials are applied to the faces only. Am I doing something wrong or is this a bug?
There was an information message from the import: V-Ray Scene Import: Unhandled object “_VolumeAerialPerspective” of type VolumeAerialPerspective.
Zip file attached with SU 2026 model, vrscene and Envision file.
SketchUp Model:
Enscape Render:
Result in Envision:
cube test.zip (1.09 MB)
