In previous versions, when I open the material editor, it automatically went to the active material. In the 3.4 preview versions (And I think it was happening in 3.3 as well) the material editor has no selected material when I open it, so every. single. time. I have to either switch to the picker and re-select the material, or browse the material list in order to select the material I want. Can you please restore the previous behavior, this is annoying.
Hey devs - are you aware or should I file a bug report?
Thanks a ton, @andybot for the report, and pardon the delayed reply, please.
I have been able to reproduce this behavior and have filed a bug for it accordingly since it wasn’t in our system yet.
I’ll notify you once more if there’ll be any news about this topic soon.
Still not fixed in the 3.4 preview 1.
Thanks for the info @andybot , I realized that as well. Allow me to look into this again, I should be back with some further news soon.
still not fixed in 3.5 preivew 1
*partially fixed actually - the picker is working now. The Enscape material window is still blank when it’s first opened (even if a material is selected in Sketchup.) but at least it changes to the correct material when using the Sketchup material dropper/picker tool.
The Enscape material window still doesn’t sync with the sketchup material selection on opening. (3.5 preview 9)
Hi ! ![]()
I don’t see the reason why this material auto-selection has been removed. This doesn’t go with convenience or time saving.
This is even more annoying on large scale projects. With my designers team, we notice that in the end, all of these useless extra clicks to select materials really created a consequent waste of time.
I really hope they can fix it back.
Or at least, give the users the possibility to fix it by ourselves.
Hey @Exhayate
Thank you for your contribution! Please forward your feedback directly to our product management team. You can do so using this web portal: https://portal.productboard.com/enscape3d/7-enscape-portal/tabs/17-under-consideration
Thank you in advance!
every. single. time. Please enscape team is there some technical limitation what is blocking this behavior or is it just not important enough? I believe it has been submitted to the portal multiple times, but i still do not understand what opinions or votes do you expect? How many votes and separate threads are needed for improving workflow for users?
