Hi all,
Can someone help me create this material as the reference?
Thank you!
Knowing what software you are running would also help. ![]()
Max 2016.
3ds Max ships with some materials and maps. You can find there some carbon fiber textures as well. I hooked those textures to Corona material and result is pretty decent i think. In the attached fle, i left texture paths unstripped, so it should pick up those textures if your 3ds max install path is default.
Maybe this guy can help ![]()
https://forum.corona-renderer.com/ oddvisionary | Automotive R&D/Look Dev #msg133744
Thank you!
I try it!
