Material conversion vray material crashes
Material conversion vray material crashes,Is there any ruby code that can directly convert the material’s diffuse map, UV texture, transparency, retain, and remove all other parameters of the old version.This option may still need to be improved.
See the scene materials in the attachment for details.
1.rar (5.02 MB)
no crashes on my side. I can convert your materials without any problem.
Hello, @wzfwzfwzf ,
Can confirm @DCHA34 's result that conversion of SketchUp materials from your model works fine.
Please ensure you use the latest V-Ray version v6.20.01.
If the issue persists, please try again by first disabling all 3rd-party extensions in SketchUp except V-Ray.
If this does not help, please provide for investigation a crash log and dump files (located in %TEMP%) via https://support.chaos.com/hc/en-us/requests/new
Kind regards,
Peter
bugsplat.Never understood the reason,Thanks for the help.
bugsplat.rar (60.8 KB)
Thanks for the test.:slight_smile:
