I’m really for bothering everybody here but this is really super important for my workflow:
Please, please bring up the popup when importing already existing proxy materials by dragging a new proxy using the same materials into the scene. When using a standard geometry I have 3 options: use existing material, replace existing material and rename material. This is super practical! If I am inserting 10 proxy variations of the same tree using the same materials, I will receive 10 copies of this one material! They are created by vray and automatically numbered: ie Bark 1, Bark 2, Bark #3 and so. But they are all the same material. For complex scenes this makes a quick reediting of ie the bark color nearly impossible. So please, please bring back this simple popup.
Or like @Micha has suggested: Allow to merge copies of the same material to one. This would be an acceptable workaround.
Dear vray team,
i have actually the same problem with Proxy-Materials: Here a sceenshot:
Furthermore can I change the scaling of a .vrmesh file? Some proxies are scaled x1000 or x0.001. I work for architecture in meters and it is a bit annoying to scale everything again and again. Maybe as a proxy setting: Scaling and x,y,z position when inserting.
Thanks for the great work!
I love to use V-Ray for Rhino. By the way a larger library would be nice
Hi guys, I’ve logged an improvement request (internal ID number - VRW-2935) so our devs can have a look and see if we can find an elegant solution. Thanks. Will let you know when there are any updates on the matter.
We are currently experimenting with ways to improve this specific workflow.
If we achieve something good we’ll make it available in one of the next V-Ray 5 updates.
