with CPU and GPU.
apply othe material working fine but changing color of the matrial(while activeshade work) dosn’t make nothing
see attachement.
Thanks.
Roy
max 2014 vray 3.03
nis_02.zip (21.3 KB)
with CPU and GPU.
see attachement.
Thanks.
Roy
max 2014 vray 3.03
Thank you for posting your test file.
Actually in my tests V-Ray RT 3.00.03 in active shade mode quickly updates any changes made for the Diffuse material color.
Would it be possible to install the latest V-Ray build 3.00.05 available on our web site and try again?
It is very odd issue. Do you have RT server running as a windows service? Do you get any warnings or errors in the RT console window?
the old fashion- restart computer solved the problem
Roy
Glad to hear that it works now.
Thank you for your update.
