Is it possible to change the preview lighting in the material editor?
Adjusting the multiplier in options doesn’t do anything when Vray is the renderer.
My materials look very dark in the mat.ed. and I was hoping to turn up the brightness a bit.
hi
Turn up the abient light in the Material editor options .. ![]()
davison, I’ve wished for this forever. Haven’t seen it updated yet but it’s probably far down on the list. Maybe it’s a limitation of Max though?
--Jon
Umm, Natty that doesn’t do anything for my Vray materials. Does it work for you?
damn … i asumed it worked for vray aswell … but it doesnt… should test these things first … ![]()
Thought I had seen it working with VRay in the past. Maybe it’s changed from build to build?
But the light Mult has never worked, I check every new build to see if it’s one of those quick little fixes Vlado does sometimes.
--Jon
yeah i was sure it did work … but hey ..
Hi!
If I remember correctly Vray does not use the ambient component.
Mare
