Material editor bug while IRP
While running IPR I can not plug in textures into the material slot, untill I select every object in the scene to which the material is applied.
All good once IPR is stopped.
This happens even when IPR is not enabled in compact material editor.
I had blend material assigned to 1 object, when I tried to copy one of the material from that blend one into another to keep them instanced, I couldn’t do that.
