Hi, I am having a problem with material editor. I am relatively new to the program, but I believe there were more materials shown here before…I have attached a screenshot.
Let me know please, thanks
Also, is there a way to permanently build a materials library so I can use on various projects?
That looks rather normal to me - In such a small scene it’s usual that there is only a limited amount of materials available with which the Enscape Material Editor can work with. In our test scene on the other hand we had a lot more materials which we’ve also imported ourselves. Feel free to do the same of course.
When it comes to building a material library of your own so to speak, please check out this knowledge base article in detail:
It elaborates what you’ll have to do if you wish to (for example) use the materials you’ve created on another machine at the same time, and/or you can always export and import any of the materials you’ll find in the Material Editor which is also detailed.
I hope that helps already, if any more specific questions come up let me know.
