I would like to start the Vantage Live Link and edit the materials through Vantage and not through V-Ray (like in Chaos Envision)
Is it possible to implement this function?
Live link is unidirectional. Modifications made in Vantage are not read by the DCC application. This is why most modifications are locked out in our UI when live link is active. We make some exceptions, for the camera etc.
Even if we implement the ability to modify the materials in Vantage, which would require properly ignoring the original scene materials for the affected objects etc., then we would still have the issue that this can not be saved back into the source scene.
I didn’t quite understand your answer, but I guess it’s not possible to implement the creation and editing of materials in Vantage on Live Link, right?
I asked this question because when I have 2 identical groups in SketchUp, Vantage autonomous doesn’t recognize this group and I can’t create a material for it, unless I create a new group or component for it, but that takes a lot of work when dealing with window frames and many identical pieces
messing with materials in vantage is wrong direction, you should do it your host app.
