Did anyone in this forum facing the same problem as this attachment? may I know how to solve it? this issue is happen randomly, even in a same scene, please help.
It seems that the “3ds Max material swatches” (Render Setup > Settings > System) option is active. Disable it to get the V-Ray swatches. Correct me if I misunderstood the issue.
My issue is as you can see in the printscreen, some material is showing material ball nut some are not, it happen randomly, I need to turn off 3ds max and re-open to solve this issue everytime when it happen,. is there anyway or any setting to avoid this happen again?
Does this happen when using Scanline? Are you using V-Ray as the Material Editor Renderer (Render Setup > Common > Assign Renderer)? I presume resetting 3ds Max to its defaults should resolve it.
I am not sure about Scanline, V-Ray is the only renderer I use, of cause yes, i am using V-Ray as the Material Editor Renderer.
Did resetting the 3ds Max preferences help? I’m pretty sure I’ve come across this way back (before our own swatches were implemented), and it’s very likely an Autodesk thing. Either way, I suggest using our own.
Kindof strange, since when using the V-Ray material swatch preview, the 3ds Max background should not be visible. Have you changed something in the .vrscene used for the swatches? I’m attaching the default one from my installation. Try replacing it (located in C:\ProgramData\Autodesk\ApplicationPlugins\VRay3dsMax2023\assets).
material_preview.7z (56 KB)
Try clearing the preview thumbnails (force a re-render) as instructed here.
