Material editor - selection
The selection and material properties update in the Enscape Materials window - this is not a problem. However there are a couple of minor details that can make it confusing:
  • The list of materials should scroll so that the current selection is in the middle of the (visible) list: currently you have to scroll to see it (admittedly it is highlighted when you find it)
  • When the material list is filtered and the results exclude the current material I think that the current selection should be included, perhaps as an italic entry?
  • Similarly, if a new material selection is made from the native application and it does not match the current filter, it will not be seen in the list of materials: I think it should be an exception to the filter and be included.
  • After clearing the filter, the list of materials re-populates but in doing so it can (again) hide the current selection out-with the visible list.
  • If you are on any of the additional texture tabs (albedo, transparency, bump, reflection) and select another texture in the native application without that tab, you get a confusing blank/empty tab rather than jumping to the General tab for that texture. (It jumps to General if another texture is selected from the pick-list within the dialogue)
Thanks @Gadget_1 , I’ll forward your feedback accordingly, as always. :slight_smile:
