Is it possible to manage materials from a Revit linked model? (We have a lot for big project with different buildings and site)
If not, how are these materials rendering?
Thanks,
Thanks,
Hi FMZ,
Yes, it is possible. Just make sure that you are linking your model (or models) to a Revit file where the materials have the same names.
If you are using the same Revit template for all projects, that would be very easy. If not - you can use the Transfer project standards command to copy all materials from the linked model to the hosting one.
Now in the hosting project you can assign V-Ray materials to all material slots. When you render, your linked models will be rendered accordingly.
Ok, works well.
Thanks for the answer ![]()
You are welcome ![]()
