I wondered whether the Cosmos generator was any good since I last tried it, so gave it another quick try based on that approach.
Simple answer is nope, not great, not even an offering of a height map after all this dev time.
With the billions that Chaos has, plus the brains, maybe they should be investigating what the competition is providing in terms of novel features, even though this is simply an addon priced at a ridiculous 15 dollars…LOL.
Maybe I’m being cynical. I think not.
My sub is running out at the end of the month and I’m daily presented with more and more reasons to not care
Yeah, that is cool. What Chaos has given us seems a little silly, since there have been apps that did much better and are now old technology. What Blender is doing is jaw-dropping.
I get what you’re saying, but looking at what one individual built, using opensource tools and selling the clearly impressive solution for an
insanely low price, he has done what the relatively more capable Chaos could not do, plus, regardless of the actual amount of cash you guys have for development
it’s doubtless vastly more than this guy has at their disposal
Hello! I’m Dan, the ML team lead at Chaos. Folks on my team were responsible for building the Material Generator models.
Firstly, thanks for trying the tool and for the feedback. I appreciate your comments on comparing it to other tools and wanting to see more value.
What would really help us is if you (or anytone else here) could send us over any examples where it’s not working as expected, including the output of the other tools. Feel free to share here, or send to dan.ring@chaos.com
I should also say that this is the first version of the Material Generator, we’re still working on it as we speak, so this is the perfect time to help us get it to where you want it.
On the Blender / Depth Anything models, we’ve actually been testing our latest work against the recent Depth Anything V3 model. Particularly when looking into adding displacement maps to our model.
When we run our internal quality & comparisons to other tools, if we’re missing the examples that are not working for you guys it’s hard for us to fix them. Hence the reason for the request.
On a wider note, when we’re developing our AI tools we usually have the option to go with an off-the-shelf model / API (e.g. Depth Anything, nano banana etc. ), or to develop our own models. Sometimes it makes sense to use an off-the-shelf model, the broad topic of Materials is important and we decided to invest the time to roll-our-own and grow our material knowledge and code base. This is important for us as it allows us to continously improve our tools, and also build future material related tools.
But again, all of this is only as good as the feedback we get, so please do send over any examples and notes
I mostly do projects which cover large areas (shopping centers, city parts, residential areas, etc) for which I need materials that really look good on larger surfaces. For these materials I always get samples that only cover small part like a square meter. Whether that are some bricks, marble, stone or concrete samples. I then need to find a way to convert these small samples to a texture for at least 10x10 meters. In the past I have been using a combination of PShop, Pixplant and ImageSynth to generate these. These days I would expect AI to help with this but having tried all (well…at least a lot) the available tools, I mostly get average results.
A perfect Material Generator should be able to generate larger textures (in dimensions) based on small samples (with the right features) accompanied by specific prompts to make changing specific features possible. If you get one (or a few) marble tile or bricks as a sample, it needs to be able to generate more tiles/bricks with the same look again combined with prompting.
I don’t do much archvis these days but when I did, like @trick I always needed brick etc., deriving from the tiny samples often provided.
The attached shows one such, which I just ran through Gemini’s nano version and then upscaled to 4k in a few minutes. So it does work for some things and would have saved me countless hours.
It’s the minimum of what I’d expect of a material generator.
Good that you show this, because it exactly shows why this is not useable (at least for me). It is not seamless, has errors and the bonding is not aligned. And if you need other bondings with the same bricks you need lots of generations before you actually have something useable.
But these kind of patterns can easily be made with generators/plugins/apps if you have a decent collections of input tiles/bricks. And these I often do not have: I need at least 20-30 different tiles/bricks to have a decent texture with 10x10m dimensions. Mostly I get 10-12, so I want AI to generate the other textures based on these.
Yes it was just a quick example. I think the point is that for Vray’s generator they need to be thinking along those lines where it meets the needs of its customers, so training it
to more do exactly what this example does, better, and with all the accompanying maps and the ability to do exactly what you said, iterate.
Yeah I remember looking there years ago. It’s just that in the UK there are really specific brick finishes that I never ever found on any sites, like that dragged finish I posted.
99% of everything I looked at was not right so spent a long time doing custom stuff that was just soul-destroyingly dull and long-winded.
Even that quick example is as I said a vast improvement.
I’m really rather glad I don’t do much architecture now, although it is infinitely simpler to do nowadays.
This is already helpful. Thanks for the discussion, and thanks @trick for that example.
Some things that have popped out already:
There’s a desired to have large areas (e.g.10x10m). Ideally taking a reference image (or multiple images) of small samples and generating something with those same patterns.
Needs to be grounded in reality / reference images, e.g. specific brick finishes. These sometimes come from sample books.
Ideally want a better version of the nano banana example
On the larger area point, do you want a larger single texture, or want say 8 tileable textures (e.g. brick sections) that could be randomised to break the monotony?
Wider question and one we’ve asked otthers: we’ve focused on adding all material types in one model, should we split it into separate workflows for different materials, e.g. bricks, concrete, marble, at the expense of not doing some other materials as well?
Another wide question, we’re currently going for a “one click” answer with some control after. What kinds of controls would you like to see?
