material ID mask from a material with opacity stacked
I have a project where we have some text and graphics on a product and would like to get a mask out for fine-tuning the color in post.
I made a quick test scene as an example of the issue I’m running in to.
I have a cube with a white glossy material on it and the graphics as a darker material with opacity stacked on top of it. In multipass I have a mask with material ID set up.
Applied over another material the mask doesn’t render, applied just on a plane, it shows up. Is this a bug or am I missing something?
I have hundreds of these renders coming up as well as dozen or so animations, so ideally I’d set this up as a multipass output rather than a separate render.
Why you dot try UV Mapping ? https://www.youtube.com/watch?v=3mOleJxt03g
What do UV maps have to do with material ID masks?
Hey, not sure what the poster means by using UV mapping either, don’t think they understand the issue or how to solve it
You could try using render selected only feature in corona.
Perhaps separate or clone the label and only apply the text you want to isolate to that and then can slot that into render selected only and that way will keep the alphas in place and you will get an isolated label/text.
hope that makes sense
Hi ficdogg, can you send us that sample scene? Chaos :smiley:
Yeah so this is an interesting question :smiley: I suppose the poster wants to know whether he can apply Material A and then Material B (with an opacity map, for example dirt) on top on the same object and get out proper masks for both materials.
Apparently it only works if it is applied on a plane but as soon as its applied on another shape it doesn’t work.
@daveclive
That could work, but the idea was to get the masks out when doing the main render, not a separate render. I have a way of quickly setting up a render where only the text/graphics show up, but even with less than 10 seconds per frame, it quickly adds up for long animations.
@nkilar
That’s exactly what I’m trying to achieve.
Attached is a test scene.
billybat_material_ID_mask_test.zip (118 KB)
Hi, did you find a way to fix this? I have the same problem
Unfortunately no, I still have to render it separately if I need it.
