if it were anti aliased, when it came time to select portions of your image from their color, the AA’d portions wouldn’t select properly, due to the changes in color caused by the blurring of edges where one color ends and another begins. That understandable?
I’ve set that up my mat ID pass using scanline and it generates AA’ed colors fine and selection in photoshop isn’t a problem, especially since I generally render pretty large. Usually twice broadcast, just for reference.
i tried writting straight to a exr file instead of an vray img file and including all the elements when I open it up in photoshop none of the layers are there, is what im doing supposed to work ?
When i open in the exr in max and get the info i see all the channels but cant access them
In my limited testing proexr does not recognize the channels. I am not sure if the PS plugin works with the channel remapping file that comes with the install. I suspect the text file is only for the orphchannels (or whatever it was called) plugin that works in AE.
