Material Library makes 3ds crash
Hello there,
i’m facing crashes of 3dsmax when I use the material library…
Often, just applying a shader to selected objects, it crashes for no reason…
It happens often, on various scene, in the example below the object is a simple box…
It’s boring as I need of course to save my scene each time I will use the library, but also bc there is no visible reason for this to crash for me…
Just wanted to report this…
See you
Please send us the mini-dump which was produced from your 3ds max crash, to acquire the file please see the following guide: https://knowledge.autodesk.com/support/3ds-max/troubleshooting/caas/sfdcarticles/sfdcarticles/Where-to-find-3ds-Max-dump-dmp-files-on-the-local-workstation-after-a-program-error-crash.html
Is this Corona version 6 hf1-2, or an earlier version?
Regards,
